Bad Throwout Bearing?
Kenya
Can you confirm that I have a bad throwout bearing? HZJ75 1HZ.
If so, how urgent is the repair? I'll fix it, but i'll need to schedule some down time.
Usually the throwout bearing will make noise when the clutch pedal is depressed. Yours sounds louder with your foot off the pedal. That noise might be coming from your trans input shaft bearing. Either way yes needs some attention.
Agreed
Definetely trow out bearing , have replaced a ton of these already on 1HZ/h55's . Since the labor is the same just install a complete new clutch , pressure plate and trow out bearing in it .
