I'll start by letting the great Willie Nelson explain how I feel right now...
I would like to thank
@Vae Victus for his H42 rebuild thread.
https://forum.ih8mud.com/threads/h42-transmission-tcase-ebrake-rebuild-in-a-76-fj40.758634/
I went back to his thread numerous times for ideas and to avoid pitfalls. Thanks again Vae. Between his thread, my pictures, a spare trans to compare with (Thank you
@Roxx), and the FSM I was able to put it all back together.
So I'm calling the trans/TC reseal project done. I have driven it approx. 30 miles since Tuesday with the trans hump, gas tank cover and passenger seat removed to shake it down. This project took a lot longer than I wanted it to but I'm ahead of my deadline, which was the All-Star race in Charlotte. I'll elaborate more about that in the ONSC chat thread.
List of jobs completed since the HAMOM:
oil pan gasket
valve cover gasket
cam access and oil galley plugs replaced
new rear motor mounts
new pilot bearing
bell house blasted and painted
flywheel turned
new clutch, pressure plate, and throw out bearing
transmission rebuilt, replaced reverse gear and 3rd/4th gear synchro
Transfer case rebuilt
parking braked rebuilt and drum turned
driveshafts rebuilt
rear pinion seal replaced
new plug wires, gapped the plugs (all were oversize)
Every part that came of was either cleaned, painted, polished or replaced.
Now some pics....
I replaced the cam access plug and oil galley plug since both looked a little weepy. This pic also shows the new rear main seal and pilot bearing. Also note the aftermarket exhaust, with this exhaust in place the flywheel will not drop down from the bell house. You can't remove the bell house without removing the flywheel.
So my work around was to use electrical wire to attach the flywheel to the bell house and then remove both as a "unit". This involved using the cherry picker because of the weight.
I ordered new front and rear motor mounts. I'll do the front mounts later. Look at those fuel lines!
Here is the trans rebuilt. This was a good day.
Here is the trans/TC installed. This was also a good day.
