Wanted b42 rad 3b
well as long as the top hose goes to the right side, and the bottom to the left i should be ok. This rad would go into a 75 fj body
well as long as the top hose goes to the passenger side, and the bottom to the drivers i should be ok. This rad would go into a 75 fj body
Passenger's side and driver's side are meaningless terms...
Also, the hose inlets changed from non-PS years to PS years due to the PS pump location.
~John
John, you make me laugh... I was thinking the same thing. I can see it making sense in the domestic market forums, but in the JDM and 24V section driver/passenger makes my head explode!
Hedge, do you have the original rad from the 75? Have you taken measurements on the rad to see if a 60, 70 or even 80 rad would fit? It might be better than the 40 series as you could get greater capacity and better cooling by rebuilding yours or sourcing a bigger one.
No but not a bad idea. also thought of something aftermarket that might fit.
i believe the 2f rad is 19" x 21.5" or so. i know i put a tape on it a wile ago but havent lately
