AXT turbo install
Nic
Langley, BC
Hi there guys, I just picked up a used axt turbo kit for my stock 3b and was wondering if anyone has any pics of their install or some literature that i can use as reference for my install. Also if anyone has some tips for me i would appreciate it. Heres what i'm planning on doing so far 1) plumb the oil return line into the pan. 2) i put new 2 1/2" exhaust front to back. Anything else i am missing? :beer:
Make sure that the oil return points straight down! You will likely need to do as I did and change the water inlet connection next to the valve cover. The way mine came from AXT was a bush and a separate 90 elbow.
There's a place on 96th Ave. in Port Kells that sells hydraulic fittings that can supply the right part. It's a white building with a blue awning at about 180th to 190th St.
