axles
Look up FJ40Jim here on Mud, he is a good source or will know of one. There are other as well.
I gather you a looking to pick them up verses having them shipped to you?
Have you looked on craigslist?
I have looked on craigslist but not as hard as maybe I should I will check fj40 jim thank u for advice
does any body know where i can order axles for 74 fj40 in ohio
What exactly are you looking for, replacement axles, chromo, whole axle assemblies, new or good used ?
If you are a little more specific i might be able to help you out too... If you are interested in just some used axle shafts i can ask around and probably come up with something... but no guaruntees :D...
:cheers:
used would be good mine are not broke just looking for extra to take when i go trailin
ok... I will put the word out... I know a couple guys that do not get here very much...
You might also get in touch with "zebrabeefj40" (nick) on here also, he might have some in his pile of parts too...
:cheers:
As gothodgie said I have used axles; complete and parts. Let me know what axle parts you are looking for and we can go from there.
:cheers:
Nick
:cheers:
Nick
i figured you had some in your pile :D....
Nick you going to have a something to wheel this summer ? if so you should try and make it to Harlan with us at the end of May...
hijack off
:cheers:
I have one rear axle I just put lockers in and was wondering how my axles would hold up I am only runin 33 12 50 tires do u guys think i should be ok I,ve had good luck with not breakin axles so far
You should be just fine on 33's... unless u have some horse power under the hood...
:cheers:
I used to wheel a '77FJ40 with a fairly strong V8, locked stock axles and 33" Swampers. I found I had almost broken one axle in the 30K miles of daily driving and wheeling 2-3 times a month in New England. I say almost because I didn't find the partially broken axle shaft until after I parted the truck out. Went to pull the shafts for spares and found one axle shaft with the splines ALMOST torn away from the rest of the shaft. No idea how long I drove it that way. :eek:
Short answer: you should be fine with stock axles and 33's. ;)
Nick
That's cool i guess i'll just run er til she breaks and go from there.
I've been ridin & wheelin forever but mostly jeeps, kinda new to the fj40 world.
It's nice to know there is people out there that know what they are talkin about.
Not many fj40s in my area.
