ok, so I completely tore down the front axle on my BJ70 to give it a total overhaul, bearings, seals, rebuilt 3rds w/ 4.56 gears, the works. It was long overdue and I wanted to get rid if the stock brake lines & backing plate set-up at the same time to make trail repairs easier.
My PS goes together without a hitch, everything works great...then comes the DS, I get everything together and get to the point where I'm installing the C clip onto the end of the Birf and the damn thing won't go on....It's about 1 mm short of the C clip seating properly.
So I break out a 12mm bolt and thread it into the end of the Birf so I can give it a yank...nope, no go. So I take everything apart again to see if the rotor/hub assembly is seating on the spindle properly....yep, looks good. The rear hub seal is seated flush with the hub, the new bearing races are all seated right....ok, lets put the rotor/hub back on the spindle....everything looks perfect except when I put the outer bearing on along with the thrust washer and the adjusting nut, I bearly have any threads left on the spindle! WTF???? Basially the entire Hub/Rotor assembly with the wheel bearings is sticking out off the spindle 1-2 mm too far out
I've triple checked every single thing from the knuckle to the spindle and everything is right....this is not rocket science for christ sakes!
So I decide, fawk it....I put everything together and run w/o the C clip.....but now when I put my brake caliper on, the outside of my rotor rubs against the caliper making it impossibe the turn the rotor by hand......Has anyone ever experienced this??? Any ideas? I'm desperate here...
