Auxiliary Fuseblock (1 Viewer)
Atlanta
Website
www.prequel.agency
Since I'm going to be adding a few things with significant power-draw, e.g., stereo amp, winch, lights, etc. I'm thinking I should add another fuse block. I don't want do a dual battery setup. I'm hoping the stock alternator will be fine, but not opposed to upgrading that.
Anyone added another fuse block? Any tips or advice? Brands?
Thanks!
Got it.
Blue Sea Systems...
Blue Sea has another one that has combination of midi and normal fuses. Called the Safety Hub IIRC. Might be useful if you have some bigger amp draws.
Thanks @jgranthevagrant - I'll look at that one too. I'm thinking the amp and maybe a small compressor will be the big draws. The winch will go to the battery.
1/0 direct off the battery for winch.
How many watt stereo amp? Id run that direct off the battery probably.
Stock alt isnt very good. Run a 94amp GM 3 wire swap. In any event I dont think the stock alt wire is any good.
Look at mil spec battery terminals.
Put a group 65 batt in it.
