Auxbeam - Ignition only fuse engine fuse box?
Atlanta, Ga
Good evening, mudders!
Trying to finish up my auxbeam switch panel install but can’t find a good fuse to tap into the engine bay fuse box? Every fuse I tap into the switch panel illuminates when the truck is off. Been working on this for far too long. Thanks in advance
You're 2011 should be exactly as mine is. Find the ignition tap in the engine fuse box here:
