autozone hard brake lines
Utah
everything on their wall said 3/16" but it seems like the stock lines are 10mm. the threads from the 3/6 will go into the factory soft line but they feel a bit sloppy until it's snugged down. is this a problem? do i need to try napa or someone other parts store that will carry exactly the right size? i really don't want to have to have hard lines made if i can avoid it.
Russ-
DO NOT use ASE fittings in a metric thread hole.
10 x 1.0 tube nut thread size
:beer:
NAPA usually has hardline with metric fittings, they have different lengths that you can choose from. I usually bought the lines from NAPA and cut off one side, made new flare...
thanks guys. i'll head to napa and check. autozone didn't have anything with a metric fitting.
