automatic transmission oil temperature warning light with 4wd (1 Viewer)
Hungary
Ho un problema con la spia della temperatura dell'olio del cambio automatico.
Ho già letto vari argomenti ma non ho trovato nulla per il mio problema.
La spia olio si accende quando inserisco le 4 ruote, appena premo il pulsante si accende la spia olio. Se tolgo il 4wd la spia olio si spegne dopo 30 secondi o qualche minuto dopo.
Ovviamente l'olio non è caldo, si avvia anche a motore freddo.
dove pensi che dovrei cercare di risolvere?
English Translation: (via google translate)
“I have a problem with the automatic transmission oil temperature light.
I have already read various topics but found nothing for my problem.
The oil warning light comes on when I insert the 4 wheels, as soon as I press the button the oil warning light comes on. If I take off the 4wd the oil warning light goes out after 30 seconds or a few minutes later.
Obviously the oil is not hot, it starts even when the engine is cold.
Where do you think I should try to solve?”
Speriamo che qualcuno qui possa aiutarti a risolvere questo problema.
La maggior parte delle persone qui parla inglese.
Including myself.
I don't understand why google translates into Italian what I wrote in English, forgive me.
I have already read various topics but have not found anything for my problem.
where do you think i should try to solve?
