Automatic ln130 stuck in park>??
canada
i jumped into my truck and went to drive but the shifter button on my surf wouldn't compress.
After a little bit of research i thought it could possibly be a fuse but after checking both fuse boxes everything looked good.
I found a cheap full shifter assembly but after completely switching that out, but no luck. when i press the button i can hear the relay under the dash. brakes lights come on when i press the pedal too.
my idea is that the shifter interlock solenoid is not fully working, i believe its supposed to retract letting you compress the shifter button thus going into gear but mine doesn't seem to do that.
any ideas are appreciated👍
