I've had an Aussie Locker in my rear axle for eight or nine months now, and I love it. More or less un-noticeable on the highway, kicks butt off road, cheap.
Lately however, is seems like the extra backlash is more noticeable. There is a great deal of slack in the rear driveline that translates into some serious clunks and thunks. Definitely unpleasant.
I realize that the basic design of an auto-locker creates more slack in the drive line, and I did notice the extra slack when I first installed the locker. It just seems more pronounced now. I've been running 85w140, per Aussie Locker recommendations, changed the fluid a month or so after the install. Maybe my cheapo gear oil is plain worn out, maybe it's not standing up to the summer temps around here. I plan on changing it out this week. Going to try adding some LSD/Locker additive from Amsoil (recommended by Amsoil for LSD's and auto-locker type devices to reduce noise and make things smoother). If that doesn't make much difference, I may try a higher-performing synthetic oil.
You guys running auto-lockers--specifically the Aussie, how much slack do you notice while driving around?
How much slack do you get between your rear diff and the t-case?
I haven't tried to actually get a measurement, but I'd guesstimate I can turn the rear drive shaft 10 or 15 degrees easy (p-brake, tranny in neutral). The slack between front diff and the t-case and/or the rear diff and t-case with the tranny in Park is just a little wiggle.
Thanks for your time.
Ryan
Ryan
