Will Van
GOLD Star
- Location
- United States
Sold.
Up for sale is a swap kit to put a Dodge 5.9 liter 12-valve 6BT diesel and manual NV4500 4WD 5-speed transmission into a 1993 FZJ80. The installer will need to source the engine, transmission, and alternator (Delco Remy 28SI). This is as close to a turn-key kit as you will find.
I am asking $2,000 + shipping for the whole kit. Not willing to separate. PayPal only. PayPal address must match shipping address.
The kit includes:
Photos Below
Total Kit
Engine Mounts
Trans to T-Case Adapter Plate w/ seals and hardware
NV4500/T-Case Mount
Spud Shaft Kit
Optional Machined NV4500 Output Shaft
Feel free to ask questions or for more pics of specific things.
The kit includes:
- Engine Mounts
- Transmission Mount to work with OEM crossmember
- Trans/T-case Adapter plate between NV4500 and HF2AV
- Throttle Bracket
- Transfer Case Shifter Bracket
- Spud shaft or machined NV4500 output shaft to adapt NV4500 output to Toyota t-case input
- Wiring Harness w/ diesel tach adapter (1993)
- Power Steering Hose
- SSOR Accessory Bracket for conventional A/C compressor and Alternator
- SSOR machined coolant outlet pipe
- A/C Adapter fittings for use with factory A/C condenser and firewall hardline
- Sanden heavy duty A/C Compressor
- Full Toyota OEM manual trans pedal assembly including buckets and hardware
- "Killer Dowel Pin" kit for 6BT timing gear
- LarryB's Heavy Duty Fuel Shutoff Solenoid Kit
- Miscellaneous seals, gaskets, and adapter fittings to complete the swap
Photos Below
Total Kit
Engine Mounts
NV4500/T-Case Mount
Spud Shaft Kit
