Attn: Pin 7 mod PICTURES!!! 100 series
Zooguy
Moore, Oklahoma (South OKC)
Remove glove compartment screws at the bottom.
Remove plastic behind glove compartment three screws at the top
Remove engine control module silver box 3 gold screws ***only do not unplug just swing out of the way***
Locate transmission relay to the right unplug from the bottom make sure to press the retaining clip on the back side of the plug.
Locate pin number 7 . Extremely small but it is printed on the white plastic plug. Easily identifiable black wire with a thin Blue line.
Third wire from the right hand side. You can remove the pin out of the plug but since I didn't have the correct tools I simply cut the wire I would recommend covering with electrical tape so it doesn't accidentally short.
"Pin 7" mod.
(before anyone else corrects it) ;)
Good write up.
I'm sure everyone knows what this mod is for, but the newbies might not. Might wanna do a brief 101 on why people do this.
Do all the 100 series automatically activate center diff lock in Lo?
I still seem to have the option to center diff lock or not, in Lo, on my ‘04 LX.
THE PIN 7 MOD ONLY APPLIES TO 98 THROUGH 02 MODELS WHERE THE CENTER DIFF LOCK AUTOMATICALLY ENGAGES WHEN IN 4LOW
Just to confirm, this allows the diff lock when in 4LO to still be controlled by the "CENTER DIFF LOCK" switch? It seems like a good mod. There have been times when I would have preferred to be in 4LO without the center diff being locked.
Correct. It simply allows you to choose when or when not the center diff is locked in either high or low range.
