SOLD ATL. 2007 FJC No Rust California Truck
Year
2007
  1. FJ Cruiser
Mileage
115803
Color
Silver
Outside Link
https://atlanta.craigslist.org/nat/cto/d/atlanta-2007-toyota-fj-cruiser-built/7126267354.html
Vehicle:
2007 FJ Cruiser (California No Rust Truck)
Ext: White/titanium Met.(2JR)
Int: Dark Charcoal
4WD/ATRAC/Rear Locker
5spd Automatic Transmission
Mileage: 115,803
VIN: JTEBU11F670010432
Option List
37 TRD Performance Exhaust Port
3T Roof Rack Port
5L Rock Rails Port
CF Carpet Floor Mats & Cargo Mat Port
CQ Convenience Package Factory
DH Towing Hitch & Wire Harness Port
EL Armrest Port
FE 50 State Emissions Factory
GY Curtain Shield Airbags (Front Row and 2nd
Row) with Front Seat Side Bolster Airbags
Overview
I spent a good amount of time searching out a rust free FJC that I could keep in a second location as my summertime overlander. I found and bought it, but unfortunately my summertime escape plans have been Chernoybled. Since this is my 3rd vehicle and I need to buy a sedan to make sales calls with, the FJ has to find a new driveway.
This is a rust free California truck that I bought from the original owner last September. I flew out to Southern Cali and drove it home. He took delivery of it in April 06, apparently it was one of the first 1,000 off the boat. He built it up and added a lot of nice quality upgrades spending roughly $20k in building it (in 2007 money). The truck had been driven very little between 2013-2019 which is why the miles are reasonably low. The truck was used for its intended purpose, PO ventured around in Baja and around Borego area. There's some pin striping, some nicks & scratches, couple door dings, and one small dent in the rear upper hatch. Ive spent some time doing paint correction and It does pass the 10 foot test and shows nicely.
Having every intention of keeping it, I dove into an extensive baseline service and including replacement of all key suspension components. I took my time going through it using Toyota or high quality parts and spending a little over $5300 in just the parts to get it where it is today.
Here's what I've done since purchasing it last September starting at mileage: 114,288 (current is 115,803)
Parts spend to date: $5300 (receipts available) My service detail is attached a few posts down.
  • BG Engine cleaning treatment
  • LOF
  • Lube front & rear drive shaft
  • Lube front & rear ujont spiders
  • Replaced rear diff fluid
  • Replaced front diff fluid
  • Replaced transfer case fluid
  • Reclamped DS inner boot
  • Cleaned throttle body, air box and intake
  • Installed New Airfilter
  • Installed New Cabin Airfilter
  • Coolant System Flush- Toyota SLLC2
  • Flushed power steering circuit-Mobil1 Syn ATF
  • Replaced Spark Plugs: Toyota Denso
  • Replaced PCV- Toyota
  • Replaced Rear Brake pads- turned rotors- Akebono
  • Brake Fluid System Flush-syn DOT3
  • Installed Ironman Foam Cell Pro rear shocks
  • Installed Sky Jacker extended sway bar links- rear
  • Install Trail Tailor HD ADJ Rear Lower Control (Link) Arms
  • Install Metal Tech Rear Lower Control Arm Skids
  • Install Icon Adjustable Rear Track bar
  • Installed Ironman Foam Cell Pro front suspension- w/constant load coils
  • New KYB strut retainers
  • Installed SPC Upper Control Arms
  • Installed ICON Sway bar mount relocation
  • Installed new front sway bar links
  • Installed AGM Aux house battery with Off grid Eng. Battery Holder
  • 4Wheel Alignment & adjust rear lower control arms
  • Replaced window belt weather strip back door DS & PS
  • Installed Transmission Oil cooler
  • Flushed entire transmission system-(at radiator return) Performed trans fluid level check procedure
  • Armored 40" Light bar installed
  • Removed cable rope and replaced with 100' 3/8" Dyneema winch line 23.8K
  • Install Factor 55 offset fairlead
  • Install Factor 55 Flat link
  • Install WetOkole Front Wetsuit Seat Covers
  • R&R Alternator- DENSO Reman
  • Replaced serpentine/accessory belt- Bando
Original Build Parts List: (PO spent roughly $20k in parts & install labor)
  • ARB Deluxe Bull Bar Front Bumper
  • Warn M8000 Winch
  • IPF 6" Driving Lamps Front
  • ARB roof Rack & Fit Kit
  • WARN Rear Bumper
  • GOBI Ladder
  • VIAR Compressor & 2 gal tank
  • PIAA Flood Lamps Sides
  • Bud Built Rock Armor Skid System
  • OME Heavy Front Spings & 4 Nitrocharger Shocks
  • OME Rear Springs 896
  • Cobra Remote CB
  • Fire stick 4' Friefly &hardware
  • Dirty Parts Dual Battery Kit
  • Garmin 2720 GPS
  • 4 x 12v Outlets- including rear cargo area for fridge
  • 2x 12v Switches
  • GPS ant
  • Ext Spkr
  • Diff Breather Kit
  • 2 x Fuse Holder
  • A-track Mod
  • Ventshade
  • Body Mount Chop
  • PoComp 17" Spoke Alloy Wheels
  • Toyo MT 295/70/17
Clear Title, no accident history. I am the second owner. *Note: First owner re-titled to his business, so CarFax would effectively show 3 owners now. The paint has some pin striping, some minor scratches from previous owners adventures. There are some door dings and a small dent in the rear hatch. Full Disclosure: the inner fender bulge was present on both inner fenders and there was some minor cracking. I removed the outer fenders to get access to the inner fenderwells, stop drilled the cracks and then reinforced and sandwiched the area with Eastwood panel bonding adhesive, 18-20ga aluminum sheet and 3/16th rivets. The result has been successful. The rock rails have some scrapes and the under body protection is in good shape. Interior is clean. The truck runs strong and drives great. Overall mechanically its 9/10 and cosmetically 7/10.
CL Price is listed at: $21,900 MUD Price is $20,900
Full price offer gets free delivery with in 250 miles, C02 PowerTank. ($500 value), ARB Recovery kit, HighLift, and some other parts & goodies.
Give me a minute to post more pics. Feel free to PM me with any questions or or more detailed pics.
Thanks for looking.
More pics
More pics
More pics
More pics
Detail of baseline service
Underside pics
More
PM me know if you want any to know anything else. Thanks for looking.
Good luck Mr Buck, it looks great.
Thank you- I appreciate that. I think you need this, it'll keep all your LandCruisers company.
Appreciate the props- thanks
Sold- Thank you.
