I was just quoted $289 from the dealer to do the fluid exchange. I wonder if this is a worthwhile expense considering the amount of effort and time it takes.
I have been wondering this as well. Maybe at the end of this procedure, do the fluid level check at the proper temp?For a full AT fluid flush, why not disconnect the tranny output line where it enters the radiator and add a drain tube to it to a collecting container, drain the 2.5 quarts from the tranny pan, attach a fill hose to the radiator inlet and add 2.5 quarts of new. Then it's just a matter of running the engine long enough to capture a couple of quarts in the collection pan, add 2 quarts in the fill line, and just keep repeating until it runs clear? No need to mess with the difficult to reach fill plug.
This is exactly what I did using a 1 gal lawn/garden sprayer from HD (THIS) to pump new fluid in. Took all of 30 minutes including the proper level check procedure.For a full AT fluid flush, why not disconnect the tranny output line where it enters the radiator and add a drain tube to it to a collecting container, drain the 2.5 quarts from the tranny pan, attach a fill hose to the radiator inlet and add 2.5 quarts of new. Then it's just a matter of running the engine long enough to capture a couple of quarts in the collection pan, add 2 quarts in the fill line, and just keep repeating until it runs clear? No need to mess with the difficult to reach fill plug.
Sounds good, do you have a write up or a procedure that you followed for this?This is exactly what I did using a 1 gal lawn/garden sprayer from HD (THIS) to pump new fluid in. Took all of 30 minutes including the proper level check procedure.
Was it shifting badly before the flush? How is it shifting now?I just had a full ATF flush and fill done at a local Toyota dealer. They did a full 12 quarts. $299.
I use this as a guide... It is not exact, but it's pretty darn closeSounds good, do you have a write up or a procedure that you followed for this?
The reason I ask is because the service guy from a local Toyota dealership advised me not to do it if my truck wasnt shifting badly. He said if it had been done periodically before, then yes, do it. But, because I don't know if it has ever been done before, he said it could dislodge gunk and clog the valve body. Now I am in quandary as to whether or not I should do it
Thanks!!!I use this as a guide... It is not exact, but it's pretty darn close
