I love this forum and the info you can find. I have an overheating issue with my 1987 HJ75 Troop Carrier running a 2H with an aftermarket turbo and a H55 gearbox. i have searched this forum and found lots of great info that i have followed and tried but hasn't seemed to work.
Driving around surface streets the temp is perfect but after a mile on the freeway the temp will climb to the red then i have to pull off and turn on the heater to expel the hot air.
My Troopie has 219000 km's, ARB bullbar with winch, 2H with ARB turbo kit and 33" Goodyears. The work i have done to try and resolve this issue is as follows:
RE-CORED/ REBUILT THE RADIATOR (proff. rebuilt)
REBUILT TURBO
NEW HOSES
NEW BELTS
NEW OEM RADIATOR CAP
REPLACED THE FAN CLUTCH SILICON OIL ( THANKS BENO)
FLUSHED THE ENGINE TWICE (seems fine)
50/50 COOLANT WATER COMBO
NEW OIL AND FILTER
Im not running a thermostat at the moment yet Beno has send me a new OEM to install.
I am yet to replace the fuel filter or clean the sedementer.
Any ideas will be greatly appreciated.
Im going to put in another water temp gauge instead of relying on a 26 year old one and see if it is different. There are smart people on this forum i know someone has had the same problem. Cheers
REBUILT TURBO
NEW HOSES
NEW BELTS
NEW OIL AND FILTER
