AS-450 Winch Help
Hello all.
I just bought a Surf and think its a great piece of kit.
The winch however is not wired up and does not ever appear to have been used.
I can See where the power and earth appear to go but there is a little grey 2 prong connector. Will the winch work if this is not wired in ??. Iv read on the forums a solenoid may need to go there. can I get 1 anywhere ??
A Wiring diagram would be a great help if anyone has 1.
The winch is a AS-450. I believe this is the standard winch.
Cheers in advance.
:banana:
Right I have the winch working when wired directly to the battery and with an ignition live on the handset. I know the other small wire is for the handset to activate the solenoid and allow power. So there is no live at the winch when it does not need it.
I bought a winch solenoid :-
anyone have any idea how to wire this up ? any wiring diagrams would help :)
cheers..
Wiring for winch
Hi any luck with wiring up you toyota as-450 winch, i,ve also got the same winch so i wonder if you can give me some advice.
Many Thanks:cheers:
