- Year
- 2003
- Vehicle Model
- 100 Series
- Location
- United States
- Mileage
- 228900
Edit: Attached Toyota Service History Report and CarFax to post.
Selling my 2003 Toyota Land Cruiser with plenty of upgrades. Purchased a new vehicle (not a cruiser) and need to part ways with my 2003. I still drive this at times so mileage will increase slightly.
Asking $14,900.
Mileage: 228,900
Clean Arizona Title
VIN: JTEHT05J332034675
CarFax shows 2 minor accidents, one in 2008 and the other in 2012.
Runs and drives fine. Passed emissions here in Arizona in January 2021. Heat and A/C work great. Has rear A/C option.
I'm the 3rd owner (CarFax previously showed I was the 3rd owner, now it shows 7, not sure what's going on there.) and have owned it since June of 2020. Since purchasing it I have taken care of the following maintenance items:
06/2020 New tires: Set of 5 BFG KO2 AllTerrain tires in 275/70/R18 at 210,266 miles.
06/2020 Front wheel bearings replaced on both sides at 210,266 miles. Work completed at Camelback Toyota.
07/2020 New battery.
07/2020 New Radiator, radiator cap, new coolant hoses top and bottom, heater T's replaced, new radiator shroud, new fan and fan clutch, new coolant at 215,658 miles. Work completed at Camelback Toyota.
08/2020 Serpentine Belt Replaced at 215,795 miles. Work completed at Camelback Toyota.
09/2020 CV Boots replaced and CV axles inspected and regreased at 217,965 miles. Work completed at Camelback Toyota.
Timing Belt changed at:
86,000 Miles and 167,000 miles.
I have most service records dating back to January of 2008 when the vehicle had 64,168 miles.
Images:
Upgrades:
Front ARB Bumper.
Rear ARB Bumper with driver's side tire carrier.
5 BFG KO2 AllTerrain tires in 275/70/R18 at 210,266 miles (lots of tread left, spare unused).
Old Man Emu 3" lift.
SPC Upper Control Arms.
Slee Diff Drop.
Doug Thorley Headers.
OEM rear and intermediate mufflers replaced with a higher flowing Magnaflow muffler.
VAIS Technology SL3b-L Bluetooth Audio Streaming add-on Adapter with Bluetooth audio streaming to the factory radio.
Memphis Audio Front and Rear door speakers.
Kicker 44CWCD104 dual voice coil 10" subwoofer powered by factory amplifier. Plenty of base for me.
All interior lights replaced with LEDs.
Headlights replaced with new one piece LED units.
Slee fog light bracket for ARB front bumper.
ARB LED turn signal upgrade kit for ARB front bumper.
Rigid LED DOT compliant fog lights (includes amber covers).
Dual 8" LED bumper mounted lights with 14,400 lumens each(spot and flood covers included).
BajaDesigns Squadron Sport ditch lights in Combo pattern.
LED floodlights on rear of vehicle that are wired to come on when vehicle is in reverse gear.
Interior switch panel for exterior lighting/accesories.
ScanGuage II on dash for vehicle monitoring and diagnostics.
Bad:
The sunroof does not open, motor engages but does not move sunroof. I suspect cable either broke or seized. Have not investigated. Sunroof does not leak.
Radio antenna was missing when I originally purchased. Never replaced it since I stream via Bluetooth from my phone. Antenna motor is present.
The front passenger door lock switch does not function. Door locks and unlocks normally from drivers side or keyfob. Either loose connection or bad switch, have not taken door panel off to investigate. Window switch works fine.
The previous owner broke drivers side door switch panel tab, glued it in place. All switches, window and door lock function fine.
The passenger side steering boot has a small pin hole on the end facing the wheel.
Hood has two small bolt holes at the front edge and two small bolt holes between windshield washer nozzels. Looks as though something was mounted there in the past. Two small surface rust spots where holes are.
Asking $14,900.
Mileage: 228,900
Clean Arizona Title
Images:
Upgrades:
Front ARB Bumper.
Slee Diff Drop.
Bad:
