I put a tundra alternator in mine (130amp), and it has a smaller pulley. Photoman has a posting somewhere from some tests he's run that shows the voltage impact of the smaller pulley. I haven't replicated the test. I read my voltage in two places, one from the OBDII read out and another from a Voltmeter running from the ACC power to the sig lighter outlet. They aren't the same as OBDII usually says 13.7 - 14.4 and the other one usually says 13.3-13.7. I can also look at what my solar charge controller reads when the vehicle is off and it is 12.7 almost always. (it is in the back of the vehicle and zero gauge and six gauge wire over a long run with a fuse probably cause some voltage drop. I have an AGM battery. All other wiring is stock. Something i've noticed is on cold days the voltage runs high at first and settles in while driving. this happens on Hot days too, but it isn't as high and it settles in faster. I can't compare with an 80amp as mine died and that was the reason for the upgrade.
I know this probably doesn't help you but I thought the information might give you something to compare. I don't run a ton of accessories... yet.
