ARB Locker Leaking
I had a lot of fluid leaking out of the compressor. Tracked it down to a blocked vent line on the front diff; diff gets hot driving, oil flows up the air line to releave pressure.
Check the diff vent tube for blockage and clear out the ARB air line is my advice.
Good news, hopefully the above post is it.:D Bad news if it is not the o-ring inside the front locker is leaking and allowing the gear oil into the line, after a few engage/disengage cycles the oil travels up the line and leaks out of the valve.:frown: Really bad news is front locker has to be taken out to fix if this is it.:mad: Have seen it a few times.
Good Luck.
