ARB bumper for Sequoia? (2 Viewers)
CA
ARB site doesn't list any bumpers for 1st gen Sequoia, but I wonder if the one they list for 99-06 Tundra (ARB Sahara bar, p/n 3915060) can be used. I was always under impression that the two trucks are identical from b-pillar forward, but it appears that for some reason ARB doesn't think so.
Has anyone tried fitting Tundra ARB bar to Sequoia?
What year is your Sequoia? '05+ Sequoia has a different front bumper. I'm sure it will mount up but the fit may not be 100% on an '05+ around the grille and inside lower edge around the headlights because of the different bumper and grille.
Mine is '05. So if the only incompatibility is the cosmetic issue above this doesn't sound so bad. I can probably swap the grille and these two little plastic under-headlight thingies from a Tundra. Or just stick a LED bar in the gap between Sequoia grill and ARB bumper...
Brute Force Fab makes an '05+ Sequoia bumper.
It will fit but you will have gaps. You can use a earlier grill or a Tundra grill to help fill things out. These grills should bolt on to you stock hood but you'll still have gaps under the headlights. I'm about to mount a LC100 ARB to the front of my 06 Sequoia. I decided to go this route since I'm not a fan of the Sahara bumper and I found a CL deal I couldn't pass up. Now after having the bumper collect dust in my garage for a year I need to get off my butt and get some mounts fabbed to make it work.
