Anybody ever swapped a 3FE into a 2F powered 60?
Did you have to change the motor mounts or modify the frame?
Fred
Fred
Aseif007 said:I am in the process of doing it right now. From what I have read you do not need to modify the engine mounts. Just things like the wiring harness, power steering, gas tank w/fuel pump, fuel lines, exhaust. I have the FJ-62 wiring harness in, the FJ-60 gas tank, fuel lines, front clip, power steering lines, and exhaust off. And you need to drill a hole for the engine harness to the ECU. Others have done it successfully before me so they may chime in. Are you keeping the H42? That would be the cheapest way to do it since nothing would need to be fabbed. I hope to have it donein the next two weeks. Good luck.
