I installed a 350 tbi and 4l60e into my fj60 and Have just about finished the install I just need my drive shaft monday and a power steering line but I cannot get it to run. I bought a running engine with 109k the 4l60e is rebuilt and I had a custom harness made for the engine and transmission combo. The engine will start but will not run for more than a couple of seconds. I used a brand new walbro inline fuel pump from aztpi in tempe with the new fuel line coming straight from the tank. the oil pressure switch is brand new the iac is brand new as well as teh coolant temperature sensor. Plug wires are new distributor cap is new. If you load it up with fuel it will run for a longer time but still will not keep running. If I pump the peddle I can barely keep it going for a while. It eally seems like it isn't getting gas but I can't figure out why. I'm at a loss I have tried quite a few different things and just don't know enough about the TBI to get it figured out. Its timed as close as I can get it without it actually running. The computer is the original comuter with the engine. Any Ideas? If someone knew alot about these and could get it running I'd be willing to pay as well I just can't get it figured out. Thanks in advance for anyhelp.
