Any one use amsoil? Im a dealer and I am picking up a big order at the warehouse in this coming weekend in VA and I wanted to check to see if any one in the club wanted some at a club price. Just pm me and I can give you a club/tlca discount.
Is it still a true group 4 oil??? I used to use it all the time after mobil 1 dropped down to a group 3 but that was on high horsepower engines.... haven't ever used it in the cruiser.
So as a dealer will you also have club prices on bypass oil filter kits?
R
Shoot, with tbe 4BTA and the 1HZ the oil is black immediately after the changekinda' scares me when the oil is sooty after 5k
I was running it in my Duramax, with very good results. I had a noticeable increase in fuel economy after switching from Dino. But, then it got to be a hassle, and it's expensive, so I switched to Mobil1 - saw a drop in fuel economy, and switched to RotellaT Syn. - I am seeing similar results from the cheap Shell as the Amsoil, so I'll probably stick with that.
I didn't ever extend the drain intervals as recommended by Amsoil - kinda' scares me when the oil is sooty after 5k, to keep stretching it. I was going to have an analysis done, but never got around to it. So the ROI is probably higher for those that follow their recommendations for DI.
R
10-14 thousand miles on a single oil change??? Holy s*** man. Do you have a bypass filtration system or anything?
Just a word on bypass filtration from blackstone labs if anyone wants to know the "basic" use of it and how long they say you can go on the same oil 1,000,000 miles![]()
Just to reiterate the point stated above, you CAN NOT simply put a bypass oil filtration system on your rig and use the same oil you've got now for more than 8000 miles. SERIOUS ENGINE DAMAGE (spun bearings, siezed motors, etc.) can occur. If you intend to put over 10 thousand miles on an oil change, make sure you use an oil that is designed to withstand tens of thousands of heat cycles and not break down.
For those wanting to learn about how oil works, including stabilized oils (group 3 and under) and why they SHOULD NOT be used for extended service intervals, read here:
http://www.bobistheoilguy.com/motor-oil-101/
That is a good read for anyone that doesn't know oil that well.
I should have added that to my above comments but was keeping it simple as I was on a break.
To clarify about bypass systems no on just puts one oil in and leaves it. What you do is normally you send in a oil sample to black stone or another lab and they can tell you how your oil is doing and if it is braking down at all. Also you do "replenish" the additives when you change filters as you have to add back in new oil to the tune of how much oil was in the filters when you change them.
If you are interested in bypass systems just make sure you use a quality oil. You can use a quality group III because many of them use group IV base stock PAO additives. Personally if I intended on using the same oil for as long as I could i'd start with the best oil available.![]()
Hey al do you have fat balls or fat hand syndrome? "Bypass systems no on just puts one" huh? Also the
word braking should be breaking and you are missing A s*** ton of commas! Just trying to help ya out.
