any one running a flex fan
*Another thing to add into the FAQ's so we can also say..
"RTFAQNEWB!"
:cheers:
**Notice I've also clipped in the result url using the [ url ] [ / url] so the search result link still worked. Mods, there is the option with some bb programs to save/clip/copy the results, I am not sure how much server space that would eventually tie up, maybe make an easier thing to do? *Or we all get stuck doing the clip, paste, clip, paste the url's page after age??
I might try rigging up a old ford metal fan (4 blade) . I will let ya know how it goes...........my junk is getting worked on anyway. Besides I have 4 laying here I might as well give it a wirl
god this is from old memory...
Flex-a-lite IIRC, claims a 5hp (or was it 7?) increase when going to E-fan. Since it's not driven of the crank anymore, that hp is freed up.
So that, a ford metal fan, might come with serious implications (if you're talking about the fan I think you're talking about)
Might rob a few ponies...
I looked last night after I logged off even if I can get it on I could not get it to balance correctly.
as long as the connections are sealed, it should be fine...
It's not like the water is exerting any pressure at the depths a H1 can go. Any fan should be fine.
In my heeping days I went through a few electric junkyard fans. They wouldn't even tollerate a generous splash, let alone a crossing. However they were usually Crysler fans, modern aftermarket stuff should be better built. The H1's stash theirs on top of the hood. Perhaps the fan parts (blade, motor housing, ext.) are able to keep water out because of the orientation. Simmalar to holding a cup under water with the opening on the bottom.
I’m not a big fan of direct driven fans, like flex fans, especially on systems designed for clutches. The old direct drive setups had a lower pulley ratio, so the water pump/fan turned slower. The clutch setups are overdriven, the water pump turns faster, but due to the clutch slippage the fan never turns shaft speed. But if a direct drive fan is fitted on a clutch fan setup the fan rpm is way fast, when they fail the shrapnel causes pretty impressive damage, $$$.
… Flex-a-lite IIRC, claims a 5hp (or was it 7?) increase when going to E-fan. ...
Believe all of the advertising hype you want, but where is that HP gain going to come from? If I had to guess a 22R type clutch pulls maybe 2 hp when fully on. The clutch setup is thermostat controlled by sensing the cooler output airflow temp. The thermostat valve is progressive, so most of the time is off/freewheeling or only drawing a fraction of the max possible. When fully on, it's most likely a big load event, so I would be happy to have that much power available.
Since it's not driven of the crank anymore, that hp is freed up. ...
So, where is the power to drive the fan come from? My guess would be from the same belt that drives the fan, the alternator maybe? The belt driven fan has slight friction loss, but is very efficient. So now we power it by taking mechanical power off of the same belt converting to electrical power at what 70% efficiency, run it through connections, switches loosing efficiency, the convert it back to mechanical energy using the motor with about an equal efficiency loss. To drive the same cfm fan electrically will require more belt hp.
There are a set of fan design rules that go something like this:
CFM=RPM, it changes linearly within the fan design range, 1 to 1.
Airflow restriction changes at the square.
HP changes at the cube.
In other words making twice the cfm = twice the rpm, but takes the cube of hp to driven it. It's more complicated than that, like moving that much air drives the restriction number up, so requires more power, etc.
So by removing a fan that has say 2 hp ultimate and replacing it with one that is .25 hp it will pull a fraction of the cfm through a fraction of the restriction. In other words have a fraction of the ultimate cooling capacity.
The belt setup is killer reliable, for an off road rig this is critical for me. Pretty much if the belt is on, the pump/fan turning your good to go. With the electric setup you have a ton more failure modes that will strand you. This is why most off road rigs have belt driven setups.
Water crossings, properly driven with a properly operating clutch fan are no issue. Remember it’s airflow temp controlled, so when some water is splashed into the airflow, it’s rapidly cooled and the clutch freewheels. I have opened the hood of clutched units sitting in water and the belts sling water, but the fan is barely moving, almost stopped with water only 1/4 of the way up the fan.
I’m well aware of the electric fan cars and that they work well, but they are designed to run that way, thinner, higher surface area coolers, etc, that our rigs don’t have. Most are setup that way because of packaging issues, ie the motor is transverse, etc so the pulley isn’t in the right spot to hang a fan. With the proper programming/switching tricks they can be made efficient, but wont have the same ultimate cooling capacity per belt hp.
Yes, an electric fan can be made to work, as long as the cooling load isn’t too high. But if you feel you have excessive cooling capacity and want to recover some of that hp, it’s relatively easy with the clutch setup. Simply change the clutch fluid in it to a thinner fluid and/or change the thermostat so that it comes on later. The only way I would run a primary electric fan on a off road rig would be packaging issue, like a remote radiator or engine swap where there isn’t room, but for me it would be a last resort. :hillbilly:
What happened?
this could get long. it got hot on the highway about 200 degrees pulled of let it cool down took about an hour and a half with the hood up cooled down to 160 and i started it started driving and all hell broke loose under the hood sound like rod bearing but also macking a higher pitch metal on metal noise so i had it towed home will look a bit tomorrow but the wifes convertable is tore down in my garage. and i am not sure how long this job is going to last might re gasket that one out of that 86 and go with that but i am sure tired of half assing this. :bang:
200 degrees is nothing. The rig after you shut it off may go as high as 210.
Main or a rod let go. Did you notice the oil pressure?
when i pulled off about 40 20 at idle when it went to hell 20 and lower. when i shut it off and checking heat gauge it pegged 250+. but it might have to do with the new piston and rod i put in when the valve dropped into #1 that f***ing chinese ebay head will haunt me in my sleep the rest of my life.
yikes.........yep you lost the head in the first place. Yea it can take over heating some. But damn
Ouch!! If you put in just one rod and bearing from another motor that is probably your problem. sorry to hear that.
By the way, not that it matters now, but I had an electric fan on my 4.3 in the 4runner. twice the connections melted and the wires shorted together, once a chunk of ice got to it in a water crossing and ate all the blades, so now it's gone.
the truck used to overheat in snow runs too, and it was a bad ass flex-a-lite 2800 cfm fan for mustang V8's. it moved good air through the radiator, but never seemed to push the heat out of the engine bay. with a mechanical fan you can feel the hot air coming out under the truck.
ok this is going to be a long story just so you do not think i am a dumbass. in 1998 i rebuilt a 22re from my 87 pickup, not long after the re build i drove that truck through the shanandoah river, water intered the trans and i did not realize it. the river was extremly low and the water never got over the bumper. any how the trans went the bed you could see from one side to the other and it was ifs with a tweacked fram from flexing it to much. so i pulled the engine and other parts that were good. when i got my 84 4runner i drove it for two years then the carb went bad so i converted it to toyota fi with the parts from the 87 pick up, minus gas tank,at the same time my bud gave me his 88 pickup so i just swaped his engine in it had 250 to 300 k miles (he disconected the speedometer cable at 203k because it was squeeking and drove it 120+ miles aday for about 4 yares ) so milage is unknown i put it in my truck to see how long it would last 4 years later spun the bearing . right before it spun the baerings i put a new head i bought from ebay. it whiped 2 cams and then on the bottom of the engine out of the 87 (3000) on rebuild but set for a few years the second day i drove it a valve broke and droped into #1 piston so i replaced piston (also bent the rod) so also the rod but i used the bearing from the rebuilt engine but when i talked to my bud who owns his own shop he told me it would be ok as long as i did not have to replace the rod. i took that chance and here i am. and i probably will stick with the clutch fan the more i think about it ant i might put an electric on as suplimental just in case not sure about that yet just thinking out loud. that is the very reson i do not gamble(as in card games or slots) my luck does not alow me to thanks for your in put on the fan :beer::beer:
