any loc guy want to help me out on what my problem may be?realy want to make big bear
Orange County
cross post from tech!
I just got done with this cut and turn thing. i have the caster at around 5. It use to be a deg 1 be for so it was way off. I didn't have DW be for. it just wonder around a lot. but know after i got everything together it has the biggest DW i ever been. it had a bent steering arm before so i replaced it. the toe was way off. i think about 1 " wider from the back of the tire then the inside. for i thing i set it even and then its like 66 1/4 toe in and the back has like 66 1/2 You have to have 1/4 toe in right? 35 mtrs? My speedo doesn't work but i was going around 3 gear 3,000 rpms and it started going it bad. be for i adjusted the toe in it was at 2 gear around 3000 rpms. so help a bit? any more places to check? im really lost and need to get it ready by wednesday and dont want to drive it like this at all. thanks for any tips
thanks:D
Eric
