Any ideas what this pink stuff is?
Texas
Found this pink stuff gathering ontop of the motor .Hopefully the pictures will give enough information .
Yup. Mine would be green :) but once I flush all of that out and replace it with "Toyota cool" it'll be red again
So that top line is a coolant line? I did notice it is very stiff and some cracks. Does anyone know a PN for that?
Yep, coolant. Fairly recent leak as well. Typically...if its been then for long or drips onto a part of the engine that gets very hot...it will be a light pink powder.
No, the top line goes to your Vacuum valve. The line below that IS a coolant line that goes to the throttle body, but neither one of them appear to be leaking. My guess is that it is one of the plugs in the manifold right below those lines.
how does this plug screw in? could i just tighten this or is there some sort of gasket involved?
I would first inspect the hose, then clean the coolant residue from that area. Drive it some to determine exactly where (and how bad or not) the leak is.
Only hose that looks suspect is the top hose in the picture . very dry and cracked
I'll clean everything up tonight and keep a close eye on everything .
CleneCl everything up .Got a little better look at everything .
The upper hose (even though cracked/crazed) I'm pretty sure goes back to your vacuum valve (trace it back) so it wouldn't carry coolant anyway. The hose in front of that does carry coolant to the throttle body and has an obvious split in it. I don't like the wire type constant tension clamp on it either. Also the plug on the right of the manifold is sitting 'proud' and I believe it is supposed to be flush.
Read the link that @PADDO provided, it addresses the same issue you are having.
All making sense now, I'll go in and tal the plug and see how I holds .My other concern is the hose condition, anyone know a PN for the 2?
