I imagine you havent gotten taller in 5 years
6' kinda seems to be the limit for most folks. Not any or much room to slide the seat back.
Mine is already back to rubbing on the cab and is rather upright. Luckily I dig the granny setup.
I have plenty of headroom above, plenty of windshield to see out of too but your short in space behind and lets just say in 1st its possible to pop your noggin on the back glass. Plus at that height you usually have the legs to go with it that make it b/w uncomfortable and impossible
Im 5'11 and wear a 30/32 length pant. Stock 45 seats (never realized they are 2'' shorter than 40 seats till i bought a sweet set that were too big) and drive it rather comfortably for what it is. The steering wheel shouldnt be an issue for legs as mine is awkwardly high enough to not be able to touch the ground and steer/hold with knees. However a belly could make things tight
I do put 10k miles a year on it and my biggest complaint as far as comfort/ergonomics is that long drives my shin/ankle gets sore from having my toe cocked up holding the gas for longer drives 2+ hrs mostly. HTH
maybe i can get ya some measurements as well if it helps-- body and frame are stock ish
