Currently, my 2000 LX has 164,800 on it. I bought the rig at 160k back in August. The previous owner had the timing belt replaced at 160k with full documentation. So it's my assumption that the antifreeze was last changed then. Currently, it has the green in it and I certainly know the consensus on here is to go with Toyota Red. I have always had toyotas and honestly I have had engines that were only on red and others that were only on green, never had any issues either way.
Now the PO did have records showing that the antifreeze was changed a few times, but the receipts don't say what type of antifreeze was used, so I assume it was the green. I have always heard that once it's been switched to green you kinda have to stay with the green. So today for whatever reason I decided to drain the radiator a bit to look at that the fluid. What I found concerns me because the fluid appears to be mixed. It's obvious the fluid is mostly green, but it's not straight green. So I poured some new antifreeze in a glass to compare and I would say the current fluid in the radiator has a slight orange tint to it. If I had to guess I would say it looks like 95% green and 5% red. Sorry I didn't take pics.
However, I don't know for sure how long the green has been in there. There is the off chance it has only been in there for the last 5k. Should I flush it out and stay green or switch to the red?
I have a friend that swears he blew his head gasket because he went from the green to the red and thinks he didn't flush it out enough. Thanks for the input guys.
