Also, with the non-smart unit, I don’t have it the protection from running out my starter battery when the engine isn’t running.
You can use D+ signal for turning Orion ON so it will only supply power when engine is ON
I am about to do the same with Orion TR(non-smart)-12/24 15A in combination with XT60i (middle pin to negative (-) ) to Ecoflow Delta MAX 2000 (13A max for solar here in Europe, for USA specs says max 10A ! but I think is mistake ) for maximum wattage when engine is running !
My question is: does MPPT of Ecoflow "takes" what it needs from 15A available or it "takes" averything available ?
I will put it to 30V just like this page says it is possible for Delta MAX ... : Orion to Delta
Best L
