We swapped out the Holley 950 Commander system referenced in my earlier post for the Downey/4.3L GM system. This is in my friend Mike's truck with a 2F.
Modified a late model distributer taking out the vacuum/mechanical advance. After the install, she would not start. After fiddling with it and rechecking several times, she started right up and ran smoothly, but then died and would not restart.
Finally got her to restatrt again after more checking and again, she promptly shut down and would not restart.
Again, late last night, we got her to start up and she ran sweet for about 5 minutes. Good throttle response, smooth idle, etc. Thought we had it..........and then she died again.
Now, after triple checking everything, she won't restatrt. No spark and no fuel spray. I am indeed gettin signal fron the dizzy. Have the gap set at .008, rechecked many times and tried .006 and .010 to no avail.
Good battery voltage with no significant voltage drop from battery to ignition circuit.
Fuel pump primes up, all connections appear to be tight, using a new Painless Harness, all new sensors, fairly new distributer, (all Toyota cap and rotor),new sensors. The only thing used is the throttle body and computer.
We did no repair nor did we find any problems prior to getting it to fire-up.
Hate to be a parts-changer trouble shooter, but I don't know what to try next.
My suspect items are the computer itself, which as I said is from a junkyard, or the ignition module.
Any input/suggestions are welcome. I'm getting tired and GSMTR is next week.
Thanks, Jim
Thanks, Jim
