another leaking question!!
fzj
I know this has been covered a million times, but I have water all over on the drivers side, the little channel that the wiring runs down was full of water and the carpet is soaked, my question is were is the water most likely coming from, I cleaned the sunroof drains today, they were clogged with pine needles etc, then I popped out the drain in the wire channel( in picture below) has anyone just left this drain out, or maybe poked a hole in it, or maybe there is another drain, if so were is the drain, and were does the sunroof drains go, my guess is right down the front a pillars by the windshield, thanks for any info
I would replace that plug as water will get in through that hole when you drive in water.
Remove the plugs under the rocker pannel. Pour water in the sunroof drain and see if it comes out the holes where you removed the plugs. Just leave those plugh out under the rocker. Do this on both driver and pass sides.
landtoy, thanks for the quick response, when you say leave the plug out of the rocker panel, which one are you talking about, I thought the rocker panel plug would be considered the one in the pic I took, and I only cleaned the drains at the top of the sunroof, I did not see were they come out exactly, maybe I need to clean that aswell, anther thins that may or may not help it when it rains outside it gets really wet right above the grab handle next to the windsheild on the drivers side, thanks again for your help!!
Craw under the vehicle. Look under the door. There is a pannel with a lip under the door. Thats the rocker pannel. WHere you see the lip you should see several small black plugs. Remove them.
ok, I am definatly learning were all of the drain systems are on my rig, ok here's what I see the rocker panel plugs(shown in pictures below) asuming these are the one's your talking about, which I belive they are, are the four plugs located across the rocker panel from front to back, here's the thing the picture that I have above showing the plug in the wiring channel removed is the same plug visible from under neath on the rocker panel, look at the below pictures the first picture shows the plug missing, whick is the exact same hole from the pictures above, the second one shows the next plug in line, and you'll notic it's still in, cause I have not yet removed that one, so should I remove all of these plugs, and were does the sunroof drain come out, thanks for all of your help landtoy, I'm really looking forward to a dry interior!
