Another Center diff lock question
NE FL
hey all,
Trying to diagnose inop CDL
Here's the scenario:
  • 153k. Lube / service history suspect.
  • No CDL lights - switch and dash. Suspect bulbs.
  • Depressed dash CDL Switch causes familiar click under dash AND I can hear actuator under truck whir.
  • No locking occurs
  • Dealer Masrer tech suggests tearing into xfer case to determine if mechanical. $$$!
I've read threads that suggest driving in figure 8, fwd and reverse, and that has not helped.
How should I proceed?
How important is this to fix? DD duties. Light offroad.
Thanks in advance.
Be 100% that there is fault, be sure it isn't locking first. Fix the bulb or jack a wheel up and try spinning the driveshafts by hand to check that the diff lock isn't engaging, lift a front wheel if you got a rear LSD.
