Amplifier plug I.D. (1 Viewer)
Maryland
I am trying to install a Parrot MKi9200 Bluetooth in my 95 Land Cruiser. I want to install it at the output of the amp so it will hopefully mute the radio sound when a call comes in, all sound system is stock. I found a few wiring diagrams and it seems like the amp output should be the two plugs that Toyota uses for all radio connections. I bought the Metra harness and clipped some pigtails from the junkyard to make my harness but my amp doesn't have those same plugs. Here is what they look like. This is the factory amp right? Behind the right side dash speaker.
Here is the harness and pigtails I have
That is indeed the amplifier, the output connector is the lower of the two plugs in the pic.
If you need to interrupt the signal there, you won't find an aftermarket adapter to do that for you.
The Metra plugs you have are for installing a new head-unit and bypassing the amp, which may be the way to go for you.
Ok Thanks. Is this the standard amp for 95-97? I guess I need to find a wiring diagram specific to 95 so I can get the pin outs. I was trying to avoid an aftermarket head unit because the Bluetooth also does streaming music so I really would only need one or the other.
