Amp/stereo specs on 99 LC
Curious if anyone knows the watt and ohm specs of the stock LC stereo system/amp. Looking to replace stock speakers, as well as rear subs.
Thoughts on replacement options for the rear subs to keep stock look with stock amp is appreciated.
Great info!!!! Thank you again. Now that i know wattage, i still need to find the ohms specs on the amp/speakers so I can match impedance.
The speakers I am currently looking to purchase are 4 ohms coaxial for the rear's and 4 omhs component for the front.
Lastly, If ohms are diff from speaker/ amp & i remove the sub speakers, could I swap the stock amp for a new 4 channel and keep original wiring back to the head unit. Basically remove the stock amp and replace it with a new 4 channel using same power cable/source/speaker wiring?
Kernal Sanders said:
Great info!!!! Thank you again. Now that i know wattage, i still need to find the ohms specs on the amp/speakers so I can match impedance. I see that the rear subs are 2 ohms, but did not know is the stock amp had a range like b/w 2-4??
4 ohms came stock on my factory speakers. I have a 99'. New clarion's sound better than stock, but amp noise much more noticeable. Also installed a iPhone fm mod, works well and very cheap upgrade to stock look, plus charges.
