Hi I'm UK based and have a 2014 Landcruiser 200, now with Geelong modified gearbox map.
Im also looking to get a set of BFG tyres on the car. Not many options for 20 inch wheels and I know 17 and 18 inch wheels were options. After a bit of research I did find that the Amazon wheels are the same PCD, bore, offset etc so assumed they would fit. The rears do but the fronts foul the callipers. Some thin spacers will do the trick. 5mm should do it. Would go to 10mm if that is all that is available.
So my question is does anyone know of any good quality spacers and longer studs that would be suitable. Ive seen lots of posts on here recommending Spidertrax but don't really want to go to 1.25 inch spacers unless I have to. Do these spacers fit with stock wheels without fouling the bodywork?
Many thanks in advance for any help
Martin
Martin
