So... (2008 Lexus LX570, 218k miles)
Went to the car wash this morning, and in the process of cleaning out my interior I accidentally moved the transfer case switch into the 4-Low position.
Upon restarting the truck, it was definitely in 4-Low, and no matter what I tried, I could not get it into High Range. I had this issue over Christmas while in Salt Lake City, Utah, and it eventually cleared up while starting the truck a day later. Drove my truck home slowly, repeating the process to get my 200 back into High Range with no luck.
Later in the garage, I removed the cupholder and with the truck off, ignition completely off, I disconnected the two white plugs that reside below the cupholder and then reconnected them for the off chance that there might be an electrical connection issue. Fast forward a little bit, and the transfer case shifts out of 4-Low and is now in normal operation. (The disconnecting of these connectors made no change in the transfer case shifting issue)
Now, my bigger issue is that my truck is now having a no start condition! When I go to start all I get is a decently loud click under the hood. Louder than a relay click, and likely the solenoid? I'm not sure if the two plugs that I disconnected and reconnected tripped any sensors, and this is an easy fix, or am I just unlucky enough today to have my starter go out in the garage (extremely lucky perhaps?)???
Anyone got any input on if the wiring on the two plugs in the shift console, under the cupholder would cause a no start condition?
I did spend several hours getting Techstream operational on my laptop again (Windows 11 update kept the old version from working) and was unable to find any trouble codes stored in the system.
