Its a Bosch Alternator, it has been rebuilt a couple of times though!
Is this a custom HO 1 wire?? 1260 series? the D+ terminal is for the idiot light connection.... does it have a W~ terminal?
OK I eliminated the old voltage regulator and used a jumper wire a that location to retain the flow of juice with the key (on) to terminal #1. It charges great 14.5vs my lights have never been brighter, but when the key switch is turned to the off position my motor continues to run. WTF?
"they are real simple....on the back they have terminals #1 & #2 #1 needs a hot wire when key is on.. #2 just jumper over to the large lug to the battery connection... "
I did just this, terminal #1 to the key on on ignition switch, #2 is jumpered over to the battery lug on the alternator. When I connect the battery back up, I saw spark coming out off the terminals. Did I miss something here???? I took out the regulator already. By the way, is the alternator now **** then after that sparK???
