secretagent said:
Hey Zach, Welcome. Do a search or go to the tech link. There are a ton of posts regarding this topic. Good luck
This was my first reaction too. Lots of info out there and many, many people with all types of car and truck have done this swap.
But I took a look for my favorite link about this swap and couldn't find it. Spent a half hour on the internet looking for it and struck out.
So I'm pasting it here with no formatting. Hope it's legible. In the meantime, I'll make an html version and ask Woody to put in Tech Links.
cheers,
theo
GM 3-wire alternator into Land Cruiser
I copied the following information from a write-up that used to be on the TLCA Tech Exchange (
http://www.tlca.org/trails/techxchg/). I don't see it there anymore but maybe I'm not looking in the right place.
Note: The following instructions, when initially published, had incorrectly switched the connections for the #1 and #2 terminals. This has been corrected. Thanks to Michael Reardon for reporting the inaccuracy, and to Mark Whatley for providing the corrections.
1. Remove the Toyota alternator and position the GM alternator in place. (You may need to use a GM positioning arm). Note that the GM unit has three electrical connection terminals, labeled Bat, #1, and #2.
2. Attach the large 'white with blue stripe' Toyota wire to the Bat terminal of the GM alternator. The other two Toyota wires, 'white with green stripe' and 'white with black stripe', are no longer needed (but see step 5).
3. Make a jumper wire with a ring terminal on one end and a female spade terminal on the other. Use this wire to jump (connect) the Bat and #2 terminals.
4. Disconnect (unplug) the Toyota regulator, which should be on the firewall below the clutch master cylinder. The Toyota regulator will no longer be needed, so you could take it off the vehicle and save a little weight (all 6 ounces).
5. Now comes the tricky part, as you have options. The 'black with yellow stripe' wire at the Toyota regulator connector is an ignition key controlled 'hot' wire coming from the engine fuse in the fuse box. This hot wire must be connected to the GM alternator #1 terminal. The options involve how you want to do this:
a. Run a wire from the 'black with yellow stripe' wire to the #1 terminal.
b. Run a wire from the engine fuse to the #1 terminal.
c. Connect the 'black with yellow stripe' wire to the now unused 'white with green stripe' wire at the regulator connector and then connect the 'white with green stripe' wire at the alternator to the #1 terminal.
Well, that should do it. Happy charging!
Richard Petruilo
I will just add a couple of notes. For those of us with GM HEI, there is an extra step needed to prevent current from feeding backwards into the ignition circuit and supplying power to the distributor, even after turning the key off. (At least, that's what I think is happening. Not too sure, though. Funny feeling to turn the key and have the engine keep running.)
I put an idiot light (charge indicator) inline in the wire that runs to terminal #1 to solve the problem. With a rubber grommet, the light fits nicely in a stock empty hole in the dash of my FJ40. Others have used a diode instead.
Also, your amp meter and related wiring may not designed for high output alternators. (My '76 FJ40 certainly isn't.) I had an episode that brought this home to me. I left my lights on all day and drained my primary battery. I jumped from my secondary battery and started home. The charge rate was so high that I saw a wisp of smoke come out from under the dash and my fusible link got too hot to touch.
I had to disconnect the alternator, drive home on no charge, and use a trickle charger overnight to bring the battery back. I am currently planning an upgrade to shunt most of the current around the amp meter.
Good luck,
Ted Christian
