Alternate injection pumps
Evansville, IN
I have a 2004 Hilux LN166 3L, and the centrifugal governor is frozen, so it won't go over 2200 rpm. I use it all the time as a work truck on gravel roads, so it's not really much of a limitation since it almost never sees the open road. However, I'd like to eventually get it fixed. I could pull the pump, send it off, and hope someone can find the parts for it; but I'm sure it would take forever and no guarantee the parts are even available for it. If I look at the parts diagram on Amayama, it lists 3 possible pumps. Mine is identified as a high altitude variation. Then there's a "normal" version, and an Egypt version. That high altitude pump appears to be very rare, but the "normal" one is available for a reasonable sum ($1300 for a Denso from Australia, or gamble on a $700 one from China, I'd buy the Denso in that choice). Is there any reason the "normal" one shouldn't be a direct swap out?
The high altitude compensator leans out fuel with lower atmospheric pressure. At least that is how it works on the older denso rotary pumps from the 90s. Theoretically swapping in a non-compensated pump shouldn't effect much. If you are at high altitude (5000ft plus) like I am, 3L will run a bit more smokey with unburnt fuel. It is incomplete combustion caused by lower air pressure.
pretty sure it would be just fine. If you do go to high altitude and floor it you might get some smoke/ high EGTs. You can always turn down the pump if it's too smoky. There are alot of good shops out there that could fix your current pump I'm sure. I bet most if not all the parts are still available.
How did you make the diagnois that the governor is the cause of the issue? If it is the case, through corrosion or gumming up of old fuel, it's likely other parts will also need to be replaced.
The high altitude compensator is pretty useless in my opinion - all it does is reduce fuelling, just the same as easing back of the accelerator when you start to see black smoke.
I would be highly suspect of $1300 for a supposedly new, genuine Denso unit, though maybe you've found a great offer. Sounds either like a fake or possibly a rebuilt unit, for which you'd need to send your old pump or pay a core charge.
If it were me, I would drop it off at a diesel specialist and ask them for an assessent. Only if it needs multiple new parts would I start looking for a replacement unit. If you ae mechanically inclined you could partially strip it down yourself and then either put it back together and get a shop to rebuild it, or trash it if it's ruined.
I ended up getting the $1300 pump. It looks like a brand new Denso pump. It was sold by an Australian ebay auto parts store that has 2051 transactions and a 98.5% approval rating; so I figured worth a gamble. I haven't had a chance to put it in yet. I suspect it's the governor because it tops out at 2300 rpm. Runs great till then, and just stops. It's not the pedal travel stop, checked that.
Can you share a link to their eBay shop? I'm interested to see what they have. Thanks.
Not a problem:
Ebay store:
I haven't visited it, but when I went back to their store, I noticed they also have a direct address at dieselpartsaustralia.com
They're also pretty responsive.
I went new thinking a rebuild would probably have a similar cost, but would potentially take far longer if they had to order any parts from overseas. And I use this truck as my field truck at work (where I'm on gravel roads the whole time, so the 50mph limit doesn't really matter), but I don't want to be without for an unknown amount of time.
Not a problem:
Ebay store:
Nice find, thanks. Indeed looks like a legitimate seller of genuine Denso parts. Would be great if you keep the thread updated and show us some pics of that nice new pump.
So I've been sitting on this pump for several months. I tried to teach my son to drive stick in it, and he took out the clutch; so I had to take it to a shop anyway. So while it was there, I had them swap out the pump also. They told me they were not a diesel shop, so all they did was swap it out and make sure the timing marks all lined up. There is no longer an RPM limit on it, but it now has no pickup. Before I had decent pickup until it hit the governed wall around 2200 rpm. Now it's a complete dog from the get go. Even with no load, it really hesitates to rev up. Lines have been bled. I know I can mess with the fuel volume screw, and that's probably what I'll end up doing; but wanted to see if anyone had any other ideas first. It was sold as a new pump, but the label doesn't look new. Maybe shelf wear? The fuel volume screw has all the original lead seals on it, although those could have been replaced.
That's definitely not a brand new pump. Maybe a new housing and head with the original data plate (the rivets have clearly been tampered with) and a reused cover. The red stuff on some external fasteners is definitely not factory.
That's not to say that the important internals aren't in perfect condition however. Because this is not the original pump from the car, the matchmarks on the pump and timing cover are not useable - the pump needs to be statically timed correctly with a dial indicator and either a cantilever SST or a dial indicator extension. Using the latter will require the starter motor be removed.
I would also check the fuel system for leaks (run the pump from a jar of diesel to bypass the tank, fuel lines, filter and filter head. And check that your accelerator linkage is correctly adjusted, i.e. that with the pedal on the floor, the pump crank is on the rev limiter.
No leaks, I'm running clear hoses. Changed the fuel filter just to be safe. Before you posted, I turned the fuel adjustment screw in 1/2 a turn and power leapt to a seat of the pants 80-90% of what it was before. I've been traveling since, so haven't been able to try and fine tune it.
