Here's a wierd one for you... Any input from people who have (or have had) the All-Pro rear disk brakes would be appreciated.
Two weeks ago I put a FJ-80 master cylinder, new rear bearings and the All-Pro rear disk conversion kit onto my truck. A major improvement over the drums when I'm trying to stop my 37's and a truck full of camping gear. No problems getting the system installed, no problems for 2 weeks...
...Coming down a pass up in Colorado this weekend, a nice little noise started up. After some playing around with it's source, it's coming from the rear brakes. They seem to be vibrating when the pedal is just pressed, giving out a very loud humm sound that you can feel in the brake pedal. Push a little bit harder and the sound goes away. Brakes feel fine throughout the process, so it's not a safety hazard (yet).
Checked the wheel lugs - the ones that hold on the rotors - TIGHT
Checked the brake caliper bolts - TIGHT
Checked the brake caliper mounting brackets - TIGHT
Pretty wierd. Anyhow, anybody ever run into this?
. I have looked at that kit a few times and it doesn't come with a proportioning valve from the looks of it. Did you happen to install one? If not it may be worth giving it a shot, the stock one is not designed for your setup and it is probably siezed up anyway. Your rear rotors may have needed to be turned from the get go because if the man in brown dropped one it could have warped it and so on, or they could have gotten too hot. I'd also check and see how the rear bearings are, since you have new calipers and they grab the rotor at one point where the drums had shoes that grabbed on opposite sides, the centrifugal (big word, geez) force could be telling you a little bit more about what may need to be fixed back there.
