alignment numbers
Kelowna, BC
Does anyone out there have their alignment numbers handy? THe numbers I'm interested in are the L/R SAI angles. On my HJ61 the right side is 9.9 but the left is 10.9. This number is out of spec according to the FSM and has also thrown my camber out on that side (-0.5). I'm suspecting a bent axle housing but want to see what other people have before I go replacing it..
Thanks
Daryl
Not necesary .. wheel bearing preload . ? did you check it . so .5 are not much.
Yes, I checked that.. the front end was completely rebuilt a year ago.. there is no play, etc in there. I am guessing that when they measure the SAI angle, they do it from the kingpin bolts?
The reason I am bothered by it is because the vehicle has pulled to the right for some time now. i've read that the front end will pull to the side with the higher positive camber..My camber is .8 difference from side to side.
Daryl
