Alignment after ball joint replacement
Middle Tennessee
Hey guys, quick question
I'm planning on replacing both lower ball joints this weekend. Do I need to do an alignment after that?
Thanks in advance
Probably no because you are not removing or loosening the lower control arm bolts. If the ball joint is 100% identical to what you are removing, then all should set at the original coordinates/positions.
There should be no reason to need an alignment after just ball joints.
Agreed with this.
UNLESS your ball joints are severely worn/clunking and your truck was aligned with them in that condition, you should be fine.
Agreed with this.
that was my idea also, but googled it and found so many opinions that I rather ask than sorry.
about previous alignment, I don't know, I bought the truck 1.5 years ago and never did an alignment before.
I will replace the AHC with OME lift within the next 3 months, I will align there for sure.
