For Sale (AL) 78' FJ45 axles
Michael B
Huntsville Al
I have a pair axles from my 78' 45 that I am replacing with cable locked units.
The front axle is currently setup for RHD (you will need to use your steering linkages if installed into a LHD rig) and has 60 series disk brakes and Asin hubs. New Toyota calipers, new rotors, new rubber hoses for calipers, new bearings and seals, 3:70 gears with an Aussie locker. Pinion back lash was setup and new pinion seal installed. $1000.00
The rear axle is Full Floating with 3:70 gears, new wheel cylinders and brake shoes, along with new inner and outer seals installed. Pinion back lash was setup and new pinion seal was installed. I have wire brushed and painted the axle since it was removed. $1500.00
All work stated in this add was performed in 2014 with about 1000 miles put on both axles since that time, on and off road. All bearings not replaced at this time were inspected and in good condition.
All prices are plus shipping which purchaser will need to arrange from Huntsville Al 35811.
Wheels are not included in this sale.
These will bolt right up to a 40, correct?
Are the doors leaning against the the 2H engine included?
Not right now. I'll check around. If you will look in the Clubhouse section go to the North American East region and post up in the HOT South Crusiers (our local club) thread I think you'll get a quicker response.
