Redneck tiltometer
old school turn and bank indicators run on gyros that are powered by vacuum, more vacuum that you would want to tap the intake for, you would need a vacuum pump, newer styles can be electric but are generally have more info and more cost
not practical unless you know where some are sitting somewhere
Or you could build a redneck version.
1. Buy a soda at McD's (or equivalent.)
2. Drink half of said soda. Put it in your factory cup holder whiile parked on a flat surface.
3. lay a protractor on the side of it.
4. Mark off about where 15 degrees is at both up and down.
5. Draw a circle around the cup at 15 degrees or so up and down from the soda line. Put one on the soda line too if you want to be fancy.
6. If the soda hits the center of the bottom line towards you, you're going downhill.
7. If the soda hits the center of the top line towards you, you're going uphill. If it exceeds it say, "yee haw."
8. If the soda hits the DS top line hang your buddy on the side as a counterweight.
9. If your lap gets wet, you're upside down.
Bottled beer works well too. Especially Bud Light. It already has markings on the side for this. Might not sit well with the local enforcement people though if you have to explain that you don't have an open container... your tiltometer is just beer based.
All scientific instruments can be calibrated with stuff you can build in your garage. Just break down the units.
