I looked at it today and the fuel goes from the tank to the manual switch to go between tanks to the sedimenter to the primer pump to the main filter to the injection pump. Don't know if that's problematic that it goes that way. Today the line that goes from the manual switch to the sedimenter was visibly damp from fuel and I saw tiny air bubbles coming from it. The line was being stressed from the angle to go down to the sedimenter from the switch and I assume over time and with the nipple putting pressure and the clamp there, it created a tiny hole. I replaced that line, figuring it was a no-brainer. That apparently wasn't the only problem, though, because I'm still getting A LOT of air in the line when I bleed it. When I went to pour fuel back into the tank, the tank definitely had built up air pressure that was released when I opened the cap. I'm including pics of the line from the tank to the manual switch just because (in reverse order of that).
View attachment 1362709 The switch is in the center top. There are three lines off of it. The one on the right goes to the auxiliary tank. The one closest goes to the main tank that the rest of the pictures are about. The farthest that is glistening is the one that I replaced and goes from the switch to the sedimenter.
View attachment 1362712 Where the line disappears, it soon changes to what is in the next photo.
