Hello!!
I've been searching through the forum, but haven't come across a similar situation. Thanks in advance!
2013 Land Cruiser
Purchased in late March 2025 w/103k miles.
After having it for a few days, I realized that the climate settings were at default (fan off and 75 degrees) each time I started the cruiser. I then realized it only resets to default when the car has been sitting an hour +
The AC blows cold and the heat works fine. The cold box and the cooling seats work
These are the 4 codes that were/are present:
23 - Pressure Sensor Circuit
47- Rear Air Mix Damper Control Servo Motor Circuit
49 - Rear Air Outlet Damper Control Servo Motor
88 -Rear Air Mix Damper Control Servo Motor Circuit on the From Passenger Side
Clear codes, immediately present.
Did some scouring on the web and people mentioned to ensure that the damper/filter in the glove box was operating correctly and properly fitted - The damper is functioning and the filter is seated properly
Found a person that was having same issues with his and he indicated that disconnecting the battery for a half hour appeared to correct the issue of resetting to default. I gave that a try and when I reconnected, I was no longer getting AC. - shorted something?!?
New additional code (in addition to the 4 others): 97 - BUS IC Communication Error
Dealer replaced the Pressure Switch
The AC was working again, but the original issue still present.
About a week after I noticed that the AC wasn’t kicking on until about 20 minutes into the drive. About a week later it was intermittently working, then nothing.
Brought it to Toyota. They looked at and said the condenser was leaking and needed to be replaced and quoted me 1800.
At this point, I wasn’t trusting them and brought it to a mechanic I know.
He checked the freon and it was low, and noticed the AC clutch wasn’t engaging.
He used his OB Computer system thing to force on the compressor - nothing.
Had the radiator and the condenser replaced (it was leaking)
I short the contacts at the relay and the compressor engages - isn’t blowing cold
Put the relay back in and the clutch isn’t engaging when the AC is turned on.
I'm wondering about the AC Amplifier, as well as, Techstream. Should Techstream have been used to reset the servos? Would that take care of 3 of the codes?
Any thoughts?
Thanks!
2013 Land Cruiser
Any thoughts?
Thanks!
