Air box mounting cushions part #?
Provo, Utah
Does anyone know what the part number is for the little rubber cushions, grommets, mounts, isolators, whatever you want to call them, that go on the air filter housing feet where they bolt to the body? I've got one that's disintegrating, and the rest of them aren't far behind. Any help would be much appreciated! I did check partsouq and amayama, but couldn't find a part number for those.
Maybe some of the veteran part people can locate a part number.
Probably need to measure a stock one and find a "Vibration Isolation Rubber Grommet" that matches.
I think the air filter housing uses M8 bolts. This is an example of one for a M8
The isolators were not serviced. You had to buy the aircleaner assembly to get them. The assemblies have been discontinued for quite some time.
