Codertimt,
I have bought a Slee override, but am contemplating put it on my 07 LC with AHC… My tires have about 10k left on them (rig is at 76k), and I just don't know what angle to turn. Should I ride with the AHC in High all the time…? Or should I buy one tire size up form stock, and just ride in Neutral and Hi sometimes….
Would you happen to have any insight on what the max tire size that can fit with an AHC in Hi 24/7? And what would fit in Neutral 24/7?
I'd appreciate your opinion.
Thanks!
That would be a question where search should turn up many threads worth of practical experience on the subject. I personally can only vouch for 295/75/16s...basically tall 33s. They fit with in N with absolutely no issues on the road. No hard off road use yet, but I expect any rubbing to be quite minimal... So, basically if not running 35s, there isn't a need to run in High all the time(and there are many opinion is different threads about what is needed for 35s...). You can always tweak the sensors and get a little lift in N, just for looks...
Codertimt,
I did have the general idea of how AHC worked but you explained it much better. I will do a minimal investment in dialing in the AHC ride and if that doesn't look like it is going to work well, I will go to standard LC suspension. Thank you for taking the time to explain the finer points.
Tom
No problem. Glad to help.
